LED technical details -- voltage etc?
Jenney will answer questions in the Codex Valoria.
You may carry on discussions in the Pre-Kickstarter News and the Kickstarter 5 Discussion Forums.
Re: LED technical details -- voltage etc?
Post by dice4hire » Tue Jan 15, 2019 1:34 am
And the shorter lived the better.
Post by AnimeSensei » Mon Jan 14, 2019 12:58 pm
102 Resin and 210 Dwarvenite Sets/Packs Owned
Post by William » Mon Jan 14, 2019 1:00 am
Wow... :?:
Post by jchunick » Fri Jul 07, 2017 4:48 pm
GroundZero wrote:
Fri Jul 07, 2017 1:19 pm
jchunick wrote:
Fri Jun 23, 2017 2:46 am
I answered this in a private message, but I'll answer it here, too. It's a 3 volt button cell battery (CR2032) that's used in all the LED pieces. You can light most LEDs from that, from a 1.8mm to a 10mm LED, and even tiny surface mount LEDs.
Do you also have the model/specs for the connectors used in KS4/5? I'm interested in doing some modding and making compatible pieces.
Also if you have a Canadian source, even better.
The JST connectors are larger than the 1.25 and the 2mm ones I have so I'm guessing that they are 3mm JST connectors?... not sure yet since this design was chosen at the point of manufacturing by the factory and I wasn't involved in that. I'll have to look up the JST spec sheets to match up the dimensions and then I can get an answer.
Post by jchunick » Fri Jul 07, 2017 4:46 pm
pacarat wrote:
Fri Jun 23, 2017 8:37 am
Any resistors needed? (always used them in my labs, but that was with 5V)
If it's a question looking for an official answer then 'yes', always use a resistor.
GroundZero
Post by GroundZero » Fri Jul 07, 2017 1:19 pm
Post by JenneyOC » Fri Jun 23, 2017 11:57 pm
Thank you Josh.
Post by pacarat » Fri Jun 23, 2017 8:37 am
Post by jchunick » Fri Jun 23, 2017 2:46 am
Post by JenneyOC » Thu Jun 22, 2017 11:31 pm
Question collected. Josh is the LED wizard, so he might actually be your best bet for this answer...
