KS5 unpainted
Re: KS5 unpainted
Post by GODofwar » Sat May 13, 2017 11:42 pm
ForestZ wrote:
Sat May 13, 2017 6:22 pm
Yeah, as someone who hand paints all their tiles, I'd also really like it to match up (since quite a lot of the "base color" shows through in my resulting paint job).
Can't one solve this problem just by using a slightly heavier base coat?
Totus KS Delenda Sunt
ForestZ
Re: KS5 unpainted
Post by ForestZ » Sat May 13, 2017 6:22 pm
Re: KS5 unpainted
Post by kodiakbear » Sat May 13, 2017 10:35 am
unclebilly wrote:
Fri May 12, 2017 8:44 pm
Please please please make sure that the KS5 tiles unpainted are the same Dark color they where in KS1 and not like the lighter color that is KS4. That way when we paint them they will match KS1.
+1
Re: KS5 unpainted
Post by Vegomatic » Sat May 13, 2017 3:01 am
Here is a thread with a primer that nearly matches the original "dungeon gray."
http://www.dwarvenforge.com/forum/viewt ... =34&t=7134
Re: KS5 unpainted
Post by dice4hire » Sat May 13, 2017 2:37 am
Here is hoping!!!!
I think I can work it out but I hope not to base coat, but sounds like I'll have to do my walls like that at least.
koraldon
Re: KS5 unpainted
Post by koraldon » Sat May 13, 2017 2:21 am
This is one thing which is really unsettling for me. I spend a lot of my gaming budget on DF and expect to get a high quality product.
For example I'm going to using mainly KS3 battlements, if the color doesn't match that will be a huge bummer for me...
Has there been any comment from DF regarding the paint? It seems terrible from photos...
Re: KS5 unpainted
Post by AnimeSensei » Sat May 13, 2017 2:11 am
Fri May 12, 2017 11:51 pm
I agree with color changes and had not known about the unpainted ksiv . I hope I can paint it to match my KSIII.😬
From what I have on hand, I think you'll need to probably base coat in a grey to get it to match 100%, but depending on your paint job you might be ok as I've noticed it's not terribly perceptible from a distance unless you're looking for it. I will say however the different colors of drybrush in the prepainted pieces are very perceptible.
Re: KS5 unpainted
Post by dice4hire » Fri May 12, 2017 11:51 pm
Smogma
Re: KS5 unpainted
Post by Smogma » Fri May 12, 2017 11:37 pm
Excellent point.
Size. Color. All these things are important to maintain through the years. This goes for everything. The tint in the Olive paint should be the same when I buy more for KS5 as it was when I bought it for KS1.
Re: KS5 unpainted
Post by pacarat » Fri May 12, 2017 9:01 pm
+1
