Small Builds
Re: Small Builds
Post by Oldent » Thu Jun 13, 2019 7:58 pm
thomast22
That is very cool, I like the double ramp :!:
thomast22
Re: Small Builds
Post by thomast22 » Thu Jun 13, 2019 7:53 pm
Some small builds
Re: Small Builds
Post by Oldent » Thu Jun 13, 2019 7:15 pm
I like the way you used the pit traps and trapdoors. I like the spiral stair case. I have been trying to print one for a path finder scenario but have had marginal results.
I did not have enough DF doors so I improvised.The spiral stair needs to fit in the same space as the narrow passage.
The 6.66 falls looks like it is 4 by 4. There looks like there is a lake that may be larger. I will work something out.
I have one mountain and lots of accessories. I will evaluate if I need more mountain elevations when I play with the new caverns.
I have 24 of the DOD elevations. I like to use them with the large columns.
blakoutsun
Re: Small Builds
Post by blakoutsun » Thu Jun 13, 2019 6:26 pm
Thu Jun 13, 2019 4:58 pm
I plain to use the magma falls with the mountain elevations to create something similar.
Will you be creating a lava lake similar to the one in your photo? I think the lavafall will look great in that setup.
blakoutsun
Re: Small Builds
Post by blakoutsun » Thu Jun 13, 2019 6:25 pm
Here is my attempt at a small build. The dungeon is an abandoned library of a long-dead wizard. Rumor has it that some of his more potent magical spells might be documented in tomes in his library. The adventurers brave enough to delve into the library will be met with guardians, traps, and a puzzle they must solve if they want to come home with the loot.
Final Treasure
More traps
Traps and Level 1 of 4
Shield Guardian and Fire Walls
Birds Eye View
Re: Small Builds
Post by Oldent » Thu Jun 13, 2019 4:58 pm
blakoutsun wrote:
Thu Jun 13, 2019 2:07 pm
Great looking build Oldent! I love the gargoyles and I think having the front open makes the whole thing feel much larger.
blakoutsun
Re: Small Builds
Post by blakoutsun » Thu Jun 13, 2019 2:07 pm
blakoutsun
Re: Small Builds
Post by blakoutsun » Thu Jun 13, 2019 2:05 pm
Thu Jun 13, 2019 6:59 am
Sounds like an interesting challenge. so a square foot footprint. ok to build up?
Building up is definitely acceptable. I love elevation in builds.
Re: Small Builds
Post by Oldent » Thu Jun 13, 2019 10:36 am
Think about the story you want to build. Add accessories like the Dollar tree grotesque. I left the front open so that the players can see.
Re: Small Builds
Post by dice4hire » Thu Jun 13, 2019 6:59 am
